RE: GMS Engine Tuning Problem
....most likely the carb is not down tight on the o-ring, and it has
an air leak there. This is common on the Tower engines as well.
Loosen the cinch bolt and press or tap the carb down tight until
the o-ring is compressed and sealing properly. Then snug the
cinch bolt back up.
FBD. [sm=teeth_smile.gif]
