Header Tank Question
Hi all!
I am installing a Saito 1.20 in a new Extra 330 I just got. I am planning to install a 2oz header-tank, and my question is:
Is the location of the main tank crucial if using a header? The problem I'm having is that the main will be located a lot lower down than the header and the carb, when the plane is upright. Inverted, the main would be about 2 inches higher up...
This is with the engine side-mounted, if I mount it inverted I get other kinds of problems such as cooling issues... I am planning to do quite a lot of 3d with the plane so equal fuel-supply would be important.
Any help would be much appreciated!
Johan
