RCU Forums - View Single Post - Use of Fuel Valve or Fuel Dot in Gasser
Old 03-13-2002 | 01:46 AM
Ed_Moorman's Avatar
Ed_Moorman
Default Fuel Dots
I recommend the fuel dot.
The valve can get a small piece of dust or grit in the valve and the engine will idle OK, but when at full power it will suck a little air and drive you crazy trying to find out what it is. I had a Quadra do this one time after I had been using as valve for some time. I was getting to send it in for service when I decided to try routing the fuel line around the valve. Worked great.
If you want to use a valve anyway, plug up the end that goes to the engine and run the tank end to a third line the same way you would a fuel dot. The valve in the middle is just looking for trouble.
