RCU Forums - View Single Post - Use of Fuel Valve or Fuel Dot in Gasser
Old 03-14-2002 | 03:07 PM
Kregg's Avatar
Kregg
My Feedback: (45)
Default Use of Fuel Valve or Fuel Dot in Gasser
Quote from above "just cut the carb line and put in a T. Run a fill line to where you want and put a plug in it. You can fill and defuel from here."
If I use this simple set up.... when I refuel, wont the gas go into the carb as well as the tank? Like wise when I defuel, wont this suck air from the carb and loose suction?
Thx
