RCU Forums - View Single Post - Use of Fuel Valve or Fuel Dot in Gasser
Old 03-15-2002 | 12:35 PM
TwoWings-RCU
Default rEFUELING tEE
bEEN USING A TEE IN THE CARB LINE FOR 15 YEARS. THE wALBRO CARB HAS A NEEDLE AND SEAT ARRANGEMENT SOMEWHAT LIKE THE AUTO CARBS(OLD STUFF NOW) HAVE. THE ADVICE IN THE OTHER POSTS IS CORRECT, JUST PUT THE TEE WHERE YOU WANT AND FILL'ER UP.
I SELDOM SAY ANYTHING BAD ABOUT A PRODUCT AS THE BAD PRODUCTS USUALLY SPEAK FOR THEMSELVES. THE SULLIVAN FUELING VALVE REALLY STINKS. BOUGHT 3 AT THE WRAMS SHOW 2 YEARS AGO AND HAVE THROWN THEM ALL AWAY. THEY LEAK FUEL OUT WHEN FUELING (RUNS DOWN THE OUTSIDE OF THE PLANE) AND TWO OF THE 3 MOLDED PLASTIC BODIES SPLIT INSIDE THE PLANE ALLOWING FUEL TO LEAK INTO THE PLANE. MAYBE SOMEONE OUT THERE HAS HAD BETTER LUCK WITH THESE BUT FOR MY $ I WILL CONTINUE TO USE A TEE ON MY GAS ENGINES.
LOU
