RCU Forums - View Single Post - best plane for begginers
Old 06-08-2008 | 01:17 PM
NorfolkSouthern
Default RE: best plane for begginers
Actually, the NexSTAR IS on Ken's list, both the ARF and RTF. I have had experience on both it, and the Hobbico SuperStar. The SuperStar compares with the Nextar with droops and flaps mounted. The main difference is that the NexSTAR doesn't handle quite as well in wind. The NexSTAR is still far more forgiving than any low-wing or high-wing that's not a trainer. There are two things that make the Nexstar stand out. One, the OS 46 FXi engine, which has ball bearings and sufficient power to handle more advanced models later. It's very similar to the .46 AX. Second, it comes with a free simulator for when a visit to the field is not an option. The main advantage I see with the SuperStar is the lower price. But, there's a trade-off: The SuperStar has an OS 40 LA, which is considered a weak engine for power. The Tower Trainer costs even less, but people have had problems with the included engine. In all honesty, you get what you pay for.
If I were deciding to get into this hobby now, I would most likely consider a Hangar-9 Alpha Trainer with the Spectrum radio. The cost is reasonable, and you get to start with a 2.4ghz radio. The Evolution 46 engine works well for some folks, maybe not everybody. The Alpha compares well to the SuperStar, and has introduced many folks to the hobby. In fact, the Alpha is what I flew on my first introductory flight. As a utility plane, the Alpha has smooth flying charactistics and good lifting ability for a video cam and telemetry equipment. In fact, trainers are more often than not, make an excellent UAV with the Nexstar being no exception.
If you want the best of the best, consider the Sig LT-40 or Kadet Senior. The LT-40 is big, stout, and has an extremely high-lift wing. It's not the prettiest, but it is considered by most RC pilots to be the best trainer available, at any cost. Both it and the Kadet Senior will fly perfectly fine with any .40 sized engine, sleeve or ball bearing including the 40 LA. And again, there's that utility vehicle capability. The Kadet Senior, in fact, is often nicknamed "The Flying SUV", and for a very good reason.
NorfolkSouthern
