RCU Forums - View Single Post - Dumbn Question
Old 06-08-2008 | 03:15 PM
jaketrouble's Avatar
jaketrouble
Default RE: Dumbn Question
i bought a cheap cheap one for i think 12 bucks.. it is a 25 watt,,,120volt 60hz.. but wattage is where the heat comes from i think... anyway,, it does do the job on the deans connectors well.. but if i were to do it again i would have gone a bit higher on the wattage..
so a 25w will do it but i reccomend a 50w if thats how they make them. jake
p.s. now that i think about it the reason i bought the 25watt one is,,well for one i did not know and then the real reason is that it is small for getting into them tight spots.. but i did seen them a little bigger with more wattage.
