RCU Forums - View Single Post - Fuji BT-24EI Kill Switch
Old 06-09-2008 | 09:52 AM
Bax
Default RE: Fuji BT-24EI Kill Switch
With electronic ignition, you put the switch in series with one of the power leads from the battery pack. When the switch is open, the engine quits. Usually, you use two switches, one manual and one servo operated. They are both in series with the power lead.
