4 flights on a good charge? otherwise best case would be to have a flying field with A/C capability. good info amigo
thanks
buck
ORIGINAL: R_Belluomini
Buck a good Deep cycle battery should get you about four charges at the field. So if you show with charged back you are good to go for the day
I fly at two fields that have 110 in the pit so I use Bulldog 45 amp power supply to run my chargers.
If you want to fly all day a generator is required for the instance were 110 is not onsite.
I have seen a nice 2 cycle generator for about $150.00 at Menards and the likes. It is supposed to run for twelve hour on a tank of fuel.
