RCU Forums - View Single Post - P-09.01 Reverse Split S and Split S Combo
Old 06-09-2008 | 05:59 PM
rcprecision's Avatar
rcprecision
Default RE: P-09.01 Reverse Split S and Split S Combo
Shannah,
The FAI 2008 Sporting Code is very clear as to when the loop segment begins relative to the 2/4 roll and roll for Manuver P-09.01...
The following was copied from the 2008 Sporting Code.
P-09.01 Reverse Split S and Split S Combo, 2/4-pt roll first, full roll second, inverted exit: From
upright, perform 2 points of a 4-pt roll, and push immediately to a half outside loop. Perform a full
roll, followed immediately by a half outside loop, to exit inverted.
Judging notes:
 The outside half loops must follow immediately after the 2/4-pt roll and roll.
 The length of the upper horizontal line (including roll) is equal to the diameter of the half loops.
The geometric shape is that of a Double Immelmann.
