RCU Forums - View Single Post - Exceed G2 problem
Old 06-09-2008 | 06:38 PM
pat35
Default RE: Exceed G2 problem
hi hey check the main bushing just below the main gears they have two set screws see if those are tight they might have come loose its happened to me also when flying that heli you need to check all the screws make sure everything is tight after every flite good luck pat35
