ORIGINAL: roboto65
Tom are you talking about the screw that holds the servo arm to the output shaft or holds the servo in the wood if it is the one for the output shaft if you have a size could you post it and I will get some for next time.. Thanks
I was referring to the screw that holds the servo arm on to the shaft. For Hitec I believe it's 2.5mm x 8mm, for JR it's 3mm x 8mm.
But since you asked getting some of the socket head servo screws that hold the servo to the mounts is a great time saver. I use them for all kinds of stuff besides mounting the servos.
TF
