RCU Forums - View Single Post - Ugly Stik build from internet plans
Thread
06-10-2008 | 12:54 AM
1
hammerd
Mar 2008
86
lv, NV
Progress on an Ugly Stik I'm building, based on the plans floating around the internet. I'm sticking pretty close to the plans, but making some changes as I see fit.
Plans sized and printing out on the plotter:
Pattern routing the ribs:
Ribs completed. The plans call for a single plywood rib for forward wing attachment. I used two:
Checking fit of the ribs:
Dry fitting the fuse parts and checking radio layout:
Glueing up fuse, and removed from table:
Tail feathers:
Attaching the landing gear. I moved the main gear aft from the plans, in line with the wing leading edge:
Triangle stock reinforcement:
Pushrod tubes:
Wing construction. Begining with laminating the spars:
Squaring up the fuse to wing and drilling the wing attach points:
Wintips and wing ready for covering:
Engine install and full mock-up:
That's it for now. I'm doing some tests using dress liner material to cover the wing.
Reply
Like
hammerd
View Public Profile
Send a private message to hammerd
Find More Posts by hammerd
View iTrader Profile
