RE: Carb too big?
Mine runs great with a CH ignition and Wt644 which is 12.75. Had to play with the timing sensor position awhile and make sure the piston is in the right BTDC. Did it run before you got it and is it broken in? Also make sure the pulse hole is open and working or make an external pulse line.
