CA hinging tip.
Ca might wick along the hinge line, even if you drop the proper amount right on the hinge due to capillary action. apply some vaseline along the hinge line, or slip in some wax paper in the hinge line. using a ca hinge to soak up stray ca is a good idea, but I guess it has to be done quickly or it will stick....
