RCU Forums - View Single Post - P-09.01 Reverse Split S and Split S Combo
Old 06-10-2008 | 11:08 AM
shannah
Default RE: P-09.01 Reverse Split S and Split S Combo
ORIGINAL: Wasson
If the description of the manoeuvre causes someone of Derk’s experience to misinterpret it, then the description needs to be improved!
Bob
http://translate.google.co.uk/transl...echt%26hl%3Den
Video in question is “Video F3a PO9 (info + K Factor)
That is interesting that you use this example. I started flying this maneuver with equal pause because I watched this video. This is my first year back flying FAI after quite a long layoff and I used this as a reference. Then, at my second local contest we had a discussion prior to the start of the contest where the clarification was made to judges that there should be no pause after wings have rolled level. It was a simple adjustment to make when flying, and it was nice to know the criteria that were being used for scoring. Hopefully, it will always be interpreted in a consistent fashion.
