ORIGINAL: Custnam
OK guys need your input. I have a DT, with a full vxl system installed. I havent changed the gearing at all, but im thinking i might have to. Although 90% of my runs are just up and down my asphault street. Ideas? Down to 14? Or ok at 16 stocker pinion?
PS, Ill unlike the pic ill be running max amp 7 cell 4700 mah.
If any of the esc, motor, or battery are getting too hot then go with a smaller pinion. If temps are fine then you can run the stock gearing. Just keep an eye on temps and let er rip.
