RCU Forums - View Single Post - NU-B needs help! * issues *
Old 05-13-2003 | 03:40 PM
dg2b
Default NU-B needs help! * issues *
I am not familiar with rs4 mini clutch but if it is the same as any other nitro clutch (i.e. shoe type) and it is plastic, then you can upgrade it to a racing grade clutch.
Does the clutch bell spin freely when the engine is not running? Does the engine die when it is running and you put the car down on the ground?
If the clutch is shoe type, your springs might be bad also.
