RE: after flight procedures?
You can either buy a checker that has a load or use a multimeter (or voltmeter) in conjunction with a 16 ohm resistor (brown blue black gold). The Hobbico Accu-Cycle charger is fairly inexpensive and will do what you need as far as cycling.
