RCU Forums - View Single Post - Smallest Gasoline engine available??
Old 06-10-2008 | 08:46 PM
Jezmo's Avatar
Jezmo
Default RE: Smallest Gasoline engine available??
ORIGINAL: buck1856
14cc echo.Not really a lot of power and probably not worth the trouble but it could be run on gas/glow and might not be bad but youll have to convert it.I had a 16cc but sold it.I do have a 14cc sitting here.Ill have to take a pic of it.later.
Hi Buck,
Please do post the pics. I have a Homie 16cc that has a cantilevered crank that was supported on the end by the mechanism to which it was mounted. (Hedgetrimmer) If I use it I will have to build a new crankcase for it as there is only one bearing supporting the crank since I took it out of the trimmer and one ain't enough. What did the 14cc echo's come on?
