RE: Evolution .46 vibration
If you are getting excessive vibrations and running problems that weren't there before, has the motor been involved in a crash or mishap? If it was it could be a slightly bent crank. Also check your bearings for play, they may need replacing also. What color locktite are you using?? I use the Blue medium. Green is the weakest and Red is the strongest.
Curt
