RCU Forums - View Single Post - 50cc Sukhette Build Thread, now in progress!!
Old 06-10-2008 | 11:59 PM
  #1153
fox6
Default RE: 50cc Sukhette Build Thread, now in progress!!
Fellas,
I am to the point of installing servos. I installed the choke servo outside the engine box with the electronic ignition module on top of the engine box. Installed the throttle servo on the lower deck in front of the fuel cell (just above the cannister mount. Rudder servo in the slot......... Question.........The servo slot in the aileron appear to be considerably longer than my servo. The rudder servo fit perfectly. What and where is the right mounting method? Will I have to glue in a piece of wood to mount aileron servo. Then, should it be mounted to the back or front of longer slot? For the elevator, which cutout do you use?
