RCU Forums - View Single Post - Nitro % question
Old 06-11-2008 | 12:05 AM
DarZeelon's Avatar
DarZeelon
Default RE: Nitro % question
ORIGINAL: Sport_Pilot
My experiance is that it is more than that. That is more like the increase without going to a cooler plug. If you do it is more like 600 to 800. Of course if the compression ratio is too high you won't see that or you may even have a performance decrease.
Hugh,
You say this as if various heat-range plugs ARE available for four-stroke engines...
Most modelers are only aware of the OS F...
They say the Fox Miracleâ„¢ is a bit colder, but its lower price is the only reason people buy it.
All other four-stroke plugs (K&B, GlowBee, Novarossi, Etc.) are not even rated as to heat range...
