RCU Forums - View Single Post - 50cc Sukhette Build Thread, now in progress!!
Old 06-11-2008 | 02:34 AM
  #1154
pupmeister's Avatar
pupmeister
Default RE: 50cc Sukhette Build Thread, now in progress!!
ORIGINAL: fox6
Fellas,
I am to the point of installing servos. I installed the choke servo outside the engine box with the electronic ignition module on top of the engine box. Installed the throttle servo on the lower deck in front of the fuel cell (just above the cannister mount. Rudder servo in the slot......... Question.........The servo slot in the aileron appear to be considerably longer than my servo. The rudder servo fit perfectly. What and where is the right mounting method? Will I have to glue in a piece of wood to mount aileron servo. Then, should it be mounted to the back or front of longer slot? For the elevator, which cutout do you use?
What servos are you using? I used HiTec 5985 for my elevators and ailerons and if I remember correctly the servos were quite a tight fit to get them in the socket. There is a photo earlier on in this thread (I can not remember where) that shows exactly which cutout you should use for the elevator servos.
Cheers
Pupmeister
