RE: Electronic Glitch - 45cc RCGF range issues
Tonight I will bypass all the switches. I will also buy a new extension that will allow me to move the ignition further up by the motor. I will add a ground from the ignition to the motor and take a deep breath! If this does not fix the problem I am not sure what to do. I have tried multiple rx's with no success. The servos are all brand new Futaba metal gear minus the throttle servo. It is nylon as well as the throttle cable.
I appreciate all your help and we will keep plugging away. WOuld a Ferrite bead placed on the plug wire make a difference?
