RE: Zero Nitro heads?
Idealy the squish band should be the same for high nitro and low nitro. But adding a shim makes the squish band taller, but one or two shims should not make a huge differance. It also depends on how well the fuel atomizes in the engine as well. Because of that this will make less differance in the summer than the winter.
