RE: Fuji BT-24EI Kill Switch
Thank you Bax. I will break out the wire cutters and make the necessary modifications.
In another thread you were asked about an adapter to install a spinner on the engine. Through the process of elimination I found that the engine prop bolt is 8 mm X 1.25 pitch. At my local hardware store I purchased a 8mm X 1.25 pitch X 55 mm bolt and suitable nut for $2.00.
I cut the head off the bolt leaving a threaded stud and found a tru turn adapter tt-0822A fits. Spinner mounting problem solved.
