RCU Forums - View Single Post - level flight problem
Old 06-11-2008 | 10:20 AM
BasinBum
Default RE: level flight problem
Engine is pointing down, trim it for half throttle and then hit full throttle it wants to pitch down. Let off the throttle and it wants to pitch up, a classic case of to much downward thrust. One or two washers to the bottom of each side of the engine mount should cure the problem.
