Lets see....Flybar, main shafts, feathering shafts (lots), blades, tail blade (no idea if the ones you mentioned work...I have always stuck with stock), landing struts...if you are getting the plastic head...then blade grips, flybar links, center hub, see saw, stabilizer control hub, tail motor mount... those are the things I have been through on my Axe when I first got it and was learning to fly it...
