RCU Forums - View Single Post - P-09.01 Reverse Split S and Split S Combo
Old 06-11-2008 | 07:13 PM
JAS's Avatar
JAS
Default RE: P-09.01 Reverse Split S and Split S Combo
That's funny that this is brought up cause it happened more than once at the Peach Classic contest. In the cases during my judging time, the plane flopped only 90-degrees off. I wasn't sure if the flop AND the correction were counted as the downgrade or just the flop. I gave a 3 for one stall turn and a 2 for the other (90-degree's off was 6 points off, plus other downgrades).
Seeing as the Nats are just around the corner, and just back from a contest, it might work to everyone’s advantage to see the link below and read through the rules for the AMA downgrades (page 18 on) for a fresh reminder.
Page 18 [link]http://www.modelaircraft.org/events/rulebooks/RC%20Aerobatics.pdf[/link]
Stall Turns: Stall turns are subject to the One Point per 15 Degree Rule, i.e., a “flopped” turn (rotation through the pitch axis rather than the yaw axis) should be downgraded one point for each 15 degrees of deviation from defined maneuver geometry. A flop of 45 degrees would earn a 3 point downgrade, while a flop of 160 degrees or more would receive a zero. These downgrades should be applied in addition to downgrades for any other defects observed in the maneuver. For example, a pendulum movement following the stall would call for an extra full point of downgrade, while a slight difference in entry and exit radii might merit an added half point deduction.
I actually questioned myself as to if there was a downgrade for the correction as well and wanted to refresh my memory as to what it was. There is no mention of it, so I was ok in what I gave as scores. They have some good notes. Like on the stall turn, 45-degree’s off is a 3-point deduction, 150+ degree’s is a zero. Add to it 90-degrees is a 6-point downgrade and it is a good “quick reference” for the stall turn.
