RE: P-09.01 Reverse Split S and Split S Combo
Jason, I interpret the stall turn rule when I'm judging exactly the same way you do. I've always been told you don't downgrade the correction. So for an automatic zero the stall must flop 150 degrees or more. Not that much difference between a 2 or 3 and a zero, but they're still better than a zero. And proper scores as far as I understand.
