RCU Forums - View Single Post - Converting a Ryobi 31cc
Old 06-12-2008 | 04:41 PM
madman75's Avatar
madman75
Default RE: Converting a Ryobi 31cc
I looked at wackerengines and didn't see any conversion for electronic ignition. I already have an S/S ignition(Roy Sholl) on hand. All that is wrong is the hall effect went bad. I called CH ign. and found out they carry the conversion kit minus the ignition system but are out of stock on them. Can you give the link for the EI conversion parts? All I saw are conversion to be used with the flywheel which I don't want. What kind of thrust numbers are possible? If this conversion works OK, I might want to use it on a 26cc Edge.
