RCU Forums - View Single Post - RC18T Steel Diff and Input gears Yes/No
Old 06-13-2008 | 02:20 AM
  #65
email4walker
Default RE: RC18T Steel Diff and Input gears Yes/No
ORIGINAL: Beomagi
I noticed the noise as well, though over time the noise does decrease as the teeth wear slightly.
if the noise is too much consider non-metal pinions.
I'm using one of these kimboroughs and it's quieter than using the steel pinion
http://www3.towerhobbies.com/cgi-bin...P?&C=CLC&V=KIM
Which pinion are you using? What are those pinion shaft sizes, 2mm? Do they come in smaller (lower number of teeth) sizes? Do they wear out quick? What pitch do we need for our rc18t's?
Thanks.
