ORIGINAL: BaldEagel
Dar
I have an MTW 75 on a purpose built manifold by Mr Pe Reivers, it has a tight bend from the exhaust outlet to miss a cowl fixing and then a double bend to bring it back into the center of the fus, I have obviously just hit on the right lengths ect.
Dear colleages:
Sorry for braking in your post, but I'm impressed with the numbers your giving. I have two MVVS45 that run perfectly, but I can't even dream with such rpm. I'm using Mobil 1 from the beginning and MTW75. Both engines are the softer and smoothest I have ever seen, progressive and reliable, but the top end is fine, but not as bright as I would like. My readings are 6.200 rpm on a Mezjlik 23x8.
You wrote about "right lengths" ... Please, could you tell me which is that length? Probably there is something I can change there ...
Thank you in advance.
Javier
