RE: Too much oil.
Same rpm on same prop would require the same torque to drive the prop.
However, our measuring equipment is not the most accurate, and atmospheric density and humidity influences these factors without one being aware of it. So slight changes in measured data cannot always be used for 100% reliablity predictions. Measurements within 5% therefore would be safe to consider as the same. (statistical Zero-option theorem)
