RCU Forums - View Single Post - Yellow Spitfire wing
Old 06-14-2008 | 10:27 AM
Spychalla Aircraft
My Feedback: (34)
Default RE: Yellow Spitfire wing
That is the bottom in front of the gear mount. The structure you see on the left is the belly scoop. No cracks on top.
I apply masking tape over the balsa on both sides of the joint and then wipe off the excess against the tape. It makes clean-up so much easier plus you don't soak the balsa. Leo
