RCU Forums - View Single Post - Decathlon / Prop Size??
Old 06-14-2008 | 10:55 AM
Deadeye's Avatar
Deadeye
Default RE: Decathlon / Prop Size??
If ST recommends the 18X8 and 18X10, then that will be fine unless you don't have the ground clearance. Wood props are usually lighter than plastic, but they also break at even the slightest ground strike.
And yes, go with a pull-pull. I use them on all my planes, down to 40 size.
