ORIGINAL: BaldEagel
On the FlightPower packs, why is it when you buy four packs all the same the cables come out in different places, some on the same side some on different sides, some with both wires at the bottom of the pack and others with them one top one bottom, it would be nice if they where consistant then you could shorten them to suit your installation and tidy everything up.
Mike
Mike,
I've been annoyed by this lately as well, they NEVER did this in the past, the wires always came out the same on every pack, one out each side. Lately I've gotten some packs with both out the side opposite the balance tap and other packs with the wires coming out opposite sides. I've decided every time I order I specify in the notes section which I prefer (I actually prefer the tap on one side and the lead wires together on the other side). I don't know if Flightpower has a second assembly plant or may be changing over to the other way and we're seeing the results of the change over but this back-and-forth is annoying (especially given their quality, seems odd that they would be inconsistent)...
Jack
