RCU Forums - View Single Post - Having a problem proforming the elevator maneuver
Old 06-14-2008 | 11:43 AM
outssider
My Feedback: (23)
Default RE: Having a problem proforming the elevator maneuver
for starters, try mixing 50% spoileron with elevator on a switch. Using spoilerons will enable even the most stubborn planes.
check to be sure the plane will fly out of the maneuver without switching the switch back. You don't want to be reaching for a switch while you're that close to the ground (especially if the wings are rocking a bit).
