RE: Help EVO 45GT!
Not all ignitions are programmable, so they do not need the programming cable. You need however the LED to check the ignition's status signals.
In the battery cable you can put a power switch. Any type that is vibration resistant and rated for about 5 amps or more.
I normally use a radio gear switch with charge bus, and if time permits I integrate a power-on check LED in it.
