RE: Decathlon / Prop Size??
An 18" prop should work on the Dynaflite (ground clearance) but it will be fairly close. I had a Pilot Decathlon, just a tad bigger than the Dynaflite, and I used an 18, it was about right on that plane, but shorter than scale for the plane (1/4). If you want scale, the full-size uses a 74" prop.
