RE: B400 reassembly question.
more then likely the chager is toast..
mine crapped out after about 6 uses.
you have to be very careful of not to over tighten almost everything that moves on the b400.
always check and recheck as put the moving parts back together.. making sure there is as little resistance as postible.
especially the belt
as you damage anything from a servo to a battery, motor or even the speed controller.
