RCU Forums - View Single Post - BH T-28 Assembly
Old 06-15-2008 | 10:41 AM
  #51
JimO
My Feedback: (7)
Default RE: BH T-28 Assembly
Fuel tank is complete and installed sort of. Will pull it out and take the photos for you. I like to use a two line and Dubro filler, so I melted shut the fill line. I use Airtronics radios and they have had the kill button on the 6 and 8000 models since their inception. I found using a fuel dot, if you don't close the throttle trim all the way you get fuel flow from the carb throat. Using the button closes off the throttle, when the engine dies releasing the button returns the throttle to the low idle position.
Nice gift, Dremel is always helpful. I took a couple of photos of the cowl and how I am cutting out for the engine and exhaust. Will post later
