RE: Wow!
The twitchiness you described was also probably caused by being slightly tail heavy. Don't adjust you're rates until you've adjusted your CG. You may find you like the existing rates.
I use dual rates on my aerobatic planes, and I also put in 50-60 percent expo. I usually use low rates for take off and landing to prevent overcontrolling.
Brad
