RCU Forums - View Single Post - What type of prop do you prefer?
Old 03-13-2002 | 03:41 AM
f2racer
Default What type of prop do you prefer?
I've flown with APC, Top Flite, and Master Airscrew (Nylon) props to date. I didn't like the Master Airscrew prop at all, it didn't seem to provide as much thrust as the others (all 10x6 sized). In terms of performance, it seemed that the Top Flite wood prop seemed to produce the most thrust (maybe because it's light), but was quite fragile, especially working in conjunction with a trainer. The APC seems like the best of both worlds, good performance, while being very durable. I'm going to try a Zinger wood prop next. I've found that unless I crash I can use a wood prop for a while with a tail dragger.
So what type of prop do you prefer?
