ORIGINAL: Sandmanvnvmc
Darin,
Are you saying that unlike the 1/10th scale 2 speed vehicles this 1/8th 2 speed has a clutch bell with one set of gears unlike the 1/10th scale 2 speeds?
Folks do not get alarmed the box is the old box but inside is nothing like the Earthquake, it is totally different than the Avalanche also. Heavier than a 1/0th scale Volcano but lighter than a 1/8th scale Avalanche. The lighter weight comes at a price, less aluminum parts for strength and of course the SH .18 instead fo the SH .28 motor, plastic pipe instead of tuned aluminum pipe. If you are looking for a fun truck to get into the hobby with this may be it, if you are looking for a truck that will hold up to hard everyday bashing spend just a little more (the value is there) and get the Avalanche.
Sandman
VNV Hobby
St. Louis
Sandman, you should pop open the sealed transmission and check it out. it is a 2 speed transmission as it should be on a truck. It does not use the a 2 speed clutchbell as the sealed tranny does the job.
Darin
