RCU Forums - View Single Post - rx interference
Old 06-16-2008 | 04:37 PM
opjose's Avatar
opjose
Default RE: rx interference
Also;
How is your throttle hooked up to the throttle servo?
Is the metal throttle horn ( the one on the carb ) hooked to a metal clevis?
In turn is the metal clevis hooked to a metal rod?
If so put in a plastic clevis.
The throttle rod is a great source of RF noise.
I've had a couple of "bad" Hitec servos that would go nuts at certain throttle settings.
At first I thought I had a bad RF noise problem, coming from the engine.
I move the servo to another channel/surface, and the problem travelled with the servo.
I replaced the bad servos with two IDENTICAL Hitecs, and changed NOTHING else. The problem went away.
I've tested the bad servos on another airframe with identical results. I sent them back for exchange, and the replacements work fine.
So it is possible that you have a couple of servos that are problematic.
