Originally posted by rcs36
I have a O.S. Max .46 FX on a trainer that works really well with a Master Airscrew 10 X 7. The take roll is alot shorter and instant power is there. Balance is also very important. I am a beginer so any thoughts on this configuration would helpful too.
Depending on what trainer you have, an APC 11x5 prop will make your plane leap off the ground. With a TT Pro 46 on my Avistar, the plane is airborne within 15 feet or so... Whack the throttle, pull hard up elevator at around 13 feet, and go vertical until the plane is a dot in the sky.
