RE: Help wire my first electric
Thanks Villian. I was able to solder what I needed this afternoon and get one of the battery packs charged. I have not mounted the motor yet so I have not checked the motor direction. If you look at the first pic you will see two small bags with the prop shafts in them. This motor mounts with the motor shaft facing forward. Should have it in the weekend. The book that came with the ESC says Futaba radios need the throttle servo reversed. I will be sure to do that when I set the radio up.
Thanks for the help again. I may have a few more questions before its ready to fly.
David
