DO NOT WORRY ABOUT BATTERY MEMORY.
To ensure you always go flying with a full charge go to your favourite discount electrical store and buy a cheap 24 hour timer switch
like
http://www.presentsforyou.com/e1020cintermatic.html?
Plug your charger into this and set it to charge for 1 hour a day.
When you come home from flying use the over ride to charge for 6 hours if you had 2 flights - 12 hours for 6 or more. [ pro rata ]
[BTW 6 + flights on standard rx packs is pushing your luck. ]
Then the timer will top it off everyday.
